Old 01-14-2019, 11:53 AM   #1
fredovvti
Drives: Yaris 07 HB
In this image, you can make more details, I 2 cable connected to the diode. Those are the negative im correct? I see to red taped together what are those?
Thank you for your response.
Sent from my SM-N950F using Tapatalk
fredovvti is offline   Reply With Quote
Old 01-15-2019, 10:52 AM   #2
DeeBee
JDM Fan!
DeeBee's Avatar
Drives: '06 Yaris
Hi fredovvti,
In the image showing the relays, yes, I connected the low beam negative and high beam negative terminals.
The relays are part of a harness I purchased to get the ballasts to turn on. Sadly, in an effort to get this mod working I butchered the harness quite a lot trying to get it to work. I'm not sure I can get it back to the way it was wired when I bought it but it works fine now.
Initially, I connected both negatives and all lights came on, all the time - Not good. Eventually I discovered that all I needed to do was connect both negatives using a diode to keep high beams off during low beam operation and during high beam operation keep the low beams on.
I am very happy with this mod because I can flash to see ahead at a corner without losing the HID wide-angle view.
Regards,
DeeBee
DeeBee is offline   Reply With Quote
FS: 2012 Yaris oem headlight projector retrofit ucsmfu Items for Sale by private party 4 11-01-2016 10:28 PM
How can i get the OEM Headlight Stalk with FOG switch to work murtaza.shahid DIY / Maintenance / Service 0 11-22-2014 06:30 AM
DIY - A EASY&FAST way to change headlight bulb ALLBLACK DIY / Maintenance / Service 0 09-18-2010 01:40 AM
FS: Seibon, HID, JDM RS Tails, Shift Knob, Oddysey PC680 Battery, etc.. -- Socal 03Z33 Items for Sale by private party 30 01-02-2009 06:55 PM
DIY - JDM RS style REPLICA tails kurokoma-kun DIY / Maintenance / Service 0 10-21-2008 02:56 PM
