Old 01-16-2019, 08:14 AM   #1
suprf1y
suprf1y's Avatar
Drives: 05 Echo
Thanks guys.
I was pretty sure but I read that there were some differences between the years like mounting brackets, etc. and saw no definitive answer. I will grab one.
I know some people don't like the higher RPM's but it doesn't bother me and my commute is 100% secondary and country roads so I don't think it's going to be a problem.
It looks like it should be about 3100 RPM at 100 km/hr which, to me, is about right for a car like this.
When I was commuting into the GTA and driving the Suzuki's one of the first things I would do is to swap in a 4.39 gear from a later 3cyl. car so at about 120 km/hr I was revving ~4000RPM and I was ok with that.
suprf1y is offline   Reply With Quote
Old 03-29-2019, 06:51 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
Originally Posted by suprf1y View Post
Thanks guys.
Oh? I never thought the manual transmission had a short final as well?
I had a 3spd auto Swift with the G16A carb engine. That thing revved 4000rpm at 120kmh as well.
06YarisRS's 2ZR-FE Swap 5-Door Hatchback (Automatic Transmission) 06YarisRS Performance Modifications 448 12-06-2018 08:12 PM
Toyota echo engine swap confirmation Brick DIY / Maintenance / Service 5 11-02-2018 05:45 PM
2001 Echo cluster swap, HELP VitzAus General Yaris / Vitz Discussion 1 02-05-2017 01:38 AM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
