Old 01-20-2019, 11:41 AM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Ok, so I tested my steering. I do not have the sounds that are audible in your audio clip. This certainly doesn't mean anything is wrong with yours.
Old 01-20-2019, 11:48 AM   #2
jowii
Drives: 2017 Yaris
Yeah, I wonder if there's just an inconsistency. Karl above seems to happen upon it with every Yaris.
When did the Yaris start incorporating EPS? I also imagine that the system could have changed over the years with different, maybe even cheaper parts. Maybe even different assemblies with the components ending up in different places? I know this Yaris has most of the components in the steering column. I'm not sure about other years of the Yaris, but I do know now that some cars with EPS have the components closer to or on the axle.
jowii is offline   Reply With Quote
Engine turns over but doesn’t start on a Yaris VVTi YarisVVTi2002 DIY / Maintenance / Service 50 03-30-2025 08:27 PM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Engine goodies for the Yaris botchilah Performance Modifications 8 01-28-2009 09:52 PM
