Old 01-20-2019, 12:23 PM   #1
My thoughts; you are getting way to inside your head about this. The Yaris makes noises, and they don't all exhibit identical characteristics.
EPS was introduced with the introduction of the Gen2, so depending on the market, model year 2006/07.
The motor mounts are somewhat sloppy and the engine will move considerably.
Sent from my EML-L09 using Tapatalk
Old 01-20-2019, 12:51 PM   #2
jowii
Drives: 2017 Yaris
Thank you. Yeah, I'm in a holding pattern right now until the next steps of the buying process...the whole process has been a bit slow and now it's a holiday weekend. So I've just had more time with the vehicle to notice more things. But they're still things I would probably question even after the purchase and good to have knowledge of to be able to diagnose potential problems later. I appreciate it.
jowii is offline   Reply With Quote
Old 01-20-2019, 04:43 PM   #3
tmontague
tmontague's Avatar
Agreed. No way 2 year old factory motor mounts are bad. The stock mounts are doughy and meant for an economic box to be as quiet as possible. If you think about this too much it will drive you crazy. There will always be odd creaks and or noises on this caliber of car (as well as many others). Bottom line, as long as the oil changes were done properly on this yaris and the rust thing checks out then you have a stupid reliable car in your hands, creak squeaks and all
Old 01-21-2019, 10:45 AM   #4
jowii
Drives: 2017 Yaris
Thanks, everybody!
Yeah the creaks I can certainly live with and they don't cause me anxiety.
It's the other mechanical stuff with the Yaris that I'm just not familiar with and want to be sure about.
Sometimes particular research can be less than helpful...when so many articles say that any sound from steering is pointing at an issue or or that bad motor mounts can be diagnosed by seeing the engine move considerable when shifting between reverse and park, etc... All of which don't account for EPS in an economy car and a car with only 2 motor mounts where many cars have 4...
So I'm happy to have found this place :)
Also the Toyota dealer I am going to has been very helpful to explain and verify these things with me as well.
Engine turns over but doesn’t start on a Yaris VVTi YarisVVTi2002 DIY / Maintenance / Service 50 03-30-2025 08:27 PM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Engine goodies for the Yaris botchilah Performance Modifications 8 01-28-2009 09:52 PM
