#1 | |
![]() ![]() ![]() Drives: 2017 Yaris L (5sp manual) Join Date: Jun 2012
#2 | |
3 Yaris and counting..
You'd think! I did! But you gotta go to a coin op. wash and stick the gun in every other hole and 'sweep' the inside of the rim. Needless to say you generally take a soaking and ends up running you $5 every time. Yea it's only $5...but this is Canada...it snows here....sometimes a lot! Hahaha
| K swapped hybrid miata build | tmontague | Off-topic / Other Cars / Everything else Discussions | 4 | 09-23-2017 01:42 AM |
| Excessive vibration over 60mph. Suspension related? | Aclosefriend | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 03-29-2016 06:06 PM |
| 1NZ-FE All Motor Build | burned | Performance Modifications | 19 | 10-24-2014 10:56 AM |
| Carbon build up in the throttle body | Sedan | DIY / Maintenance / Service | 18 | 11-15-2013 11:44 PM |
