Old 01-25-2019, 03:41 PM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Originally Posted by 06YarisRS View Post
Sam, I'll pop over to turbokits.com and look at the manifold. Have you ever given thought to parting with your manifold?
I bought it for curiosity as well as for insurance. I wasn't able to get in on the RPM long tube header before it went out of production and I'd rather not get stung that way again. You can buy just the manifold directly from TKC if you don't want to go for a full kit. They also offer packages with the manifold, down tube and your choice of turbo. Granted that's designed for the Corolla/Matrix/Vibe platform so the down tube might not be usable as is. I figure that the whole thing will need to be custom built and the manifold is the only pre-fab part I can use for sure.
Old 02-03-2019, 07:28 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Don't know how I missed this response, Sam. Thanks for it. Yes, I did see the smaller package kits at turbokits. I figured that the downpipe would work as a stock manifold for the Corolla fits and I assumed they would have maintained close dimensions. That said, having never looked under a Corolla, I'm not sure how much more room there is as compared to the Yaris. And, the diameter of the down pipe apprears significantly larger. My first concern is whether or not the manifold and turbo would actually be small enough to fit between the head and firewall, and have enough clearance for engine movement.
I agree with you that a kit for this configuration (2ZR in Yaris) is probably going to have to be mostly custom and therefore likely very expensive. Also, as far as electronic management of the system, from what I've been reading, the AEM FIC - which is more affordable - is less than ideal when compared to a standalone ecu. That alone could add close to $1000.00 to a project.
I see that a member here has a Camcon for sale and apparently it can adjust fuel and timing, but I think I read that it only works for VVTi, not Dual VVTi. Do you know anything about the Camcon?
Old 02-11-2019, 01:12 PM   #3
CrankyOldMan
Agreed. 2.25 is plenty big enough for NA, 2.5 is probably fine for mild boost. No idea what 3" would do, but they made it for this engine so I'm assuming they know what they're doing. =D
You could take a gamble and buy the Corolla kit and do some mods to it. Not the best idea since you'd need to redesign a fair bit of it.
Not familiar with those. Lots of conflicting info about piggybacking on a Toyota ECU, specifically if you can actually wrest control of the fuel trims from the ECU or if you just fight it for a few months and then reset the OEM unit.
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
3rd gen engine swap, 2ZR? 2AR? Swap newbie m.flores.0928 Third Gen Yaris General Discussion 6 10-02-2020 10:54 AM
06YarisRS's 2ZR-FE Swap 5-Door Hatchback (Automatic Transmission) 06YarisRS Performance Modifications 448 12-06-2018 08:12 PM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 09:12 AM
1zz swap...is it worth it??? jouna Performance Modifications 12 11-10-2009 09:33 PM
