Old 02-04-2019, 11:45 AM   #1
tmontague
tmontague's Avatar
Originally Posted by myfirstyota View Post
I guess I may have to take a look at mine now. I just populated an empty fuse slot with the proper connector. But with all busses being powered all the time, i can inly imagine ill also have an issue but have yet to see it. Im Also not driving the car so no reason why i would have seen it yet.
Yup, I tested all the empty and other used fuses and they were all constant power. The last one I tested was the EFI fuse and it was ignition only based on my testing and confirmation.
Keep in mind your draw will only be 110-140 mA, not 300mA like mine was since you dont have a faulty keyless entry. Still enough to slowly drain a battery but not as quickly.
Either way, having constant power to the MAF can't be helping its longevity with its temp sensor
Old 02-04-2019, 01:08 PM   #2
myfirstyota
3 Yaris and counting..
I was thinking that when I did the swap. "Its ok to have the maf powered all the time?" I came to the conclusion everything else on the buss was.... must be fine.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
2ZR MAF sensor connector info CrankyOldMan Yaris TS Talk 0 12-10-2018 03:05 PM
Dropping the tans in a 2zr swapped Vios tmontague Performance Modifications 2 04-29-2017 07:29 PM
