Old 02-04-2019, 11:55 AM   #12
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by tmontague View Post
Yes to the EFI fuse, it is one of the only ignition switches 12v sources. I moved some connectors around to make it easier to run the fuse tap wire
Awesome. Thanks. Don't have the fusebox diagram in front of me now. Hopefully my wire is long enough to reach. Were you planning a pic?
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
2ZR MAF sensor connector info CrankyOldMan Yaris TS Talk 0 12-10-2018 03:05 PM
Dropping the tans in a 2zr swapped Vios tmontague Performance Modifications 2 04-29-2017 07:29 PM
