#1 | |
True. I guess I would mainly loosely monitor that parameter in torque for significant changes in fuel consumption. Pretty much the same for other parameters like longer term changes in coolant temp, A/FR, voltage etc.
#3 | |
![]() Sent from my CLT-L04 using Tapatalk |
3 Yaris and counting..
Idle... you'll see 99L/100
Nope torque says infinite if idle.
Haha. In my van, I can see a couple hundred L per 100 km if I stomp on it.
Kinda glad I never hooked torque up to the old hemi lol
Haha, just makes you wonder how long it would take to drain a tank if you kept on it. The Lambda v6 in my van likes its fuel when tromped on, and it's obvious as this minivan is like a rocket despite being almost 2.5 tons.
| Noobie Advice Needed | ianmak | UK | 7 | 10-17-2017 02:00 PM |
| Need some advice about air filters | srm73 | Performance Modifications | 22 | 09-10-2016 11:31 PM |
| Good advice for new car owners... | YarisSedan | General Yaris / Vitz Discussion | 10 | 04-15-2009 03:43 PM |
| Legal advice needed | Rahxephon | Off-topic / Other Cars / Everything else Discussions | 8 | 09-24-2007 04:56 PM |
