Old 02-09-2019, 09:50 PM   #1
bentjazz
Drives: 2009 Yaris--3dr MT
Update, part deux. Ebay hubcap purchase didn't work out, afterall. Will be going with 06YarisRS's Amazon recommendation or I might still do the steelie thing if I can free up enough time to angle grind and paint them.
bentjazz is offline   Reply With Quote
Old 02-10-2019, 08:20 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Good luck with the project. If you plan to paint the steel wheels, are you planning to use a disc or a stiff wire wheel? I've restored several sets of steel wheels. It's much easier to do this obviously with the tires off and will make for a more long-lasting job
The process I use is basically:
1) thoroughly wash wheels (2 - 3 times with a LOT of dish soap. Rinse and repeat until a paper towel or cloth pics up no contamination. Thoroughly dry. Heat gun works great.
2) wire wheel and coarse sand paper for all rust spots, then an overall wheel sanding with something like 240 grit.
3) 2 - 3 applications of rust converter on all rust spots, about 15 minutes between each application.
4) repeat step 1
5) prime converted rust spots with a decent high build primer. Closely follow drying/curing times.
6) resand the entire wheel with 240 or finer grit.
6) Apply a light dust coat of paint. Then, apply 2 - 3 medium wet coats following drying times.
Using this process yields the best finish and longest lasting results. I always give my steel wheels an occasional blast of light rust proofing, but I drive through salt, slush and sand all winter long.
Old 02-11-2019, 12:10 AM   #3
bentjazz
I plan on using a stiff wire wheel attached to my angle grinder, 06YarisRS. Just curious, how long does it normally take you to do all four steelies? And how long does this kind of paint job last before rust reappears? Thanks so much.
Old 02-22-2019, 10:59 AM   #4
06YarisRS
Sorry, I missed this. Normally an afternoon but I go about other stuff during drying/curing times. I have a set of steeliess for my van that were done about 3 winters ago and they are holding up great. But, like I said, I keep them rustproofed. The paint on steelies from the factory is really cheap, with the more expensive OEM wheels being only slightly better.
Regarding trim rings, they look great but really only when clean. Trims rings in the winter is a bit of a waste IMO. I would avoid chrome-plated steel in favour of stainless steel, or even chrome-plated ABS. Plated steel will inevitably show rust when used in winter/salt conditions. Whichever trim rings you go with, lay a couple good coats of wax on them. I used acrylic paint sealant.
Hubcap question 2009 Yaris Sedan- URGENT mrs_yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 04-13-2016 02:21 PM
09-12 Toyota Yaris Hatchback / Sedan 8 Spoke 15" Hubcap needed! ard2014 Willing to Buy by private party 0 06-11-2014 04:16 PM
08 hubcap ryota Willing to Buy by private party 0 03-11-2013 09:08 AM
Hello! I need at least one hubcap for a 2009 Yaris Sedan txprsn Willing to Buy by private party 2 05-15-2010 04:56 PM
WTB: Hubcap and Grille LoadThis Willing to Buy by private party 9 11-05-2009 11:09 AM
