Old 02-11-2019, 10:00 PM   #1
tmontague
tmontague's Avatar
Good info on the fuse tap. I always thought they were wired parallel but I remember not having power to my additional wire when the fuse from the original line was removed from the tap.
Your 100mA parasitic draw seems a bit high. It probably will keep your battery fine for at least 5-7 days in the dead of winter and much longer in the summer, but it should definitely be below 50mA, something else is drawing current.
Start with any aftermarket/2zr swap wiring, and then pull factory fuses and see what drops the draw.
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 05:59 AM
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 12:56 PM
2ZR MAF sensor connector info CrankyOldMan Yaris TS Talk 0 12-10-2018 04:05 PM
Dropping the tans in a 2zr swapped Vios tmontague Performance Modifications 2 04-29-2017 08:29 PM
