Old 02-16-2019, 06:46 PM   #1
B.B._07
Drives: 07 5dr
You probably damaged some wiring going to the transmission in the accident and hence the tranny codes. You can get a good look at the transmission by taking out the battery and air filter housing. I'd also check under the car for any leaks from the transmission or just check the fluid level.
Vibration, occasional high idle, and other shenanigans in 2009 auto Yaris hatch firebird1999us DIY / Maintenance / Service 21 01-30-2019 11:43 AM
Rough idle when hot Ravnica General Yaris / Vitz Discussion 4 12-19-2016 03:38 PM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-07-2012 12:37 AM
