![]() ![]() Drives: yaris 2005 Join Date: Mar 2016
Plastic fastner sizes
All
Can someone please advise what are the plastic fastner sizes used in yaris on Tyres boots etc.. Many thanks Sent from my SM-G930F using Tapatalk |
#2 | |
![]() ![]() ![]() Drives: 2003 Mach 1 Join Date: Oct 2008
If so I switched to these things: http://www.yarisworld.com/forums/showthread.php?t=56837 |
#3 | |
![]() Drives: 2007 Toyota Yaris Sedan BASE Join Date: Oct 2018
Yes some called th3se rivets some say its plastic fastners
I think there are three sizes i have seen but it would be good if someone provide what type dimensions they are. Also what size bolts nuts are used in yaris i think its all 14mm. There are couple of nuts at the bottom of the front wheel i think they are 9mm Thanks Sent from my SM-G930F using Tapatalk |
![]() ![]() Drives: Yaris 2008 Sedan Join Date: Nov 2010
This might help you get part numbers then you can maybe find specs from there. https://www.toyotapartsdirect.ca/Toy...-and-Trim.html
| How to change plastic cover inside wheel well | komichal | DIY / Maintenance / Service | 0 | 07-14-2018 03:39 PM |
| Front wheel well plastic question? | Pinchlite | Cosmetic Modifications (Exterior/Interior) | 19 | 03-28-2017 08:10 PM |
| i've stopped | thebarber | Off-topic / Other Cars / Everything else Discussions | 37 | 12-30-2011 05:52 PM |
| plastic and rubber on the yaris.. | matanfr | Wash, Wax, Detailing, Exterior Repairs | 15 | 01-18-2011 05:03 PM |
