Old 02-24-2019, 06:36 PM   #1
2bz
Drives: 2008 Yaris 3DR Hatch MT
"Many people will replace the air fuel sensor or O2 sensor as soon as they get a bad reading, but the root cause is often a dirty or faulty mass air flow sensor or vacuum leak, thus causing the O2 or A/F sensor to read differently to compensate. Reading and analyzing fuel trims and the freeze frame data is the key to properly diagnosing P0171."
Fuel pump could be an issue also.
2bz is offline   Reply With Quote
Need Help with 2NZ ECU pinout Aleil DIY / Maintenance / Service 3 12-28-2020 09:40 AM
2013 yaris 2nz yaser DIY / Maintenance / Service 0 12-14-2015 07:47 AM
2nz pistons in 1nz salmanghiyas Performance Modifications 1 11-15-2014 01:30 PM
1NZ / 2NZ Transmission Compatibility & Aftermarket 2NZ Rods jtw11 Performance Modifications 8 09-03-2013 01:49 PM
Turbo for 2NZ.... Centurion2200 Forced Induction Forum 9 08-25-2007 06:14 AM
