Old 03-16-2019, 08:58 PM   #1
dogsridewith
Drives: 2007 2-door hatchback
How would the coolant darkening relate to a blocked PCV valve?
I had a small block Chevy metal PCV valve clicking so loudly that I adjusted the valves on that side before discovering what it was. It wasn't dirty, and the same looking (and same acting, in hand) replacement PCV valve was quiet.
Old 03-16-2019, 09:54 PM   #2
tmontague
tmontague's Avatar
Excess crankcase pressure can do strange things.
It may not necessarily be causing the coolant issue but it is the simplest thing to check and rule out so it should be done first
Old 03-17-2019, 07:14 AM   #3
2bz
Drives: 2008 Yaris 3DR Hatch MT
Over pressure damage to head/other gaskets allowing oil and or combustion gasses to mingle with coolant.
2bz is offline   Reply With Quote
brown coolant, burnt oil, decreased performance, engine noise
Does anybody have the 2011 TMMF Yaris owner's manual? alexei General Yaris / Vitz Discussion 2 09-05-2013 04:20 PM
FS For Sale Toyota TRD Exhaust Yaris Sedan lll3 Items for Sale by private party 6 04-18-2013 03:07 PM
Yaris Sedan Vs. Yaris 4dr. hatch Meow General Yaris / Vitz Discussion 11 10-29-2006 02:11 PM
