#55 |
3 Yaris and counting..
![]() New pics on first page!
No one suspects the Yaris. Xd/2zr-fe Swap/Build Thread http://www.yarisworld.com/forums/showthread.php?t=61427 Bolt-in 3.75" Suspension Lift Build Thread http://www.yarisworld.com/forums/showthread.php?t=61577 Last edited by myfirstyota; 03-24-2019 at 07:24 PM. |
#56 |
![]() Drives: Yaris hatchback 06 Join Date: Nov 2018
Hahaha awesome. That look perfect with that tire size.
Did you cut the front only for stock heigh whit this tire? |
#57 |
I cut the front bumper cause of body damage originally.. I hit a hiway caution barrel that was overturned with its base toward traffic somewhere between Kingston and the 416 to Ottawa. There were no reflectors to be seen. I cut the fractured section of the front bumper off and cut the other side to match, knowing it would add to my off road look. I will mention agan I'm running scion xD front fender liners. They "kinda" fit but are a bit more roomy than the yaris ones.
I'm expecting major trimming for the larger tires. Also, I'd like to run some pretty wide spacers or very offset wheels. And probably fender flares to keep the cops at bay :) Also it seems there may be some leverage factor to my lift as it looks taller than I thought it would. The spring is located close to the fulcrum of the axle, being the mounting points. The wheel being further down the arm may generate more lift at the end? Anyone with a 3 or 4 door hatch on stock springs wanna measure from ground to the jack points for me? At no point was i under 12" to mine!
No one suspects the Yaris. Xd/2zr-fe Swap/Build Thread http://www.yarisworld.com/forums/showthread.php?t=61427 Bolt-in 3.75" Suspension Lift Build Thread http://www.yarisworld.com/forums/showthread.php?t=61577 Last edited by myfirstyota; 03-24-2019 at 07:18 PM. |
#58 |
150 successful km so far. Hiway speeds of 120+km/h. Drives fine though I'd be weary of high speed lane changes for emergency purposes. Its not short anymore. Hoping the front lift and spacer or rim offset corrects it a bit.
#59 |
![]() Drives: 2008 Toyota Yaris 5dr Liftback Join Date: Jul 2012
That’s a hefty lift going on there! Some trimming and bigger tires will look awesome on it.
My 4 door hatch measures at 8” ground to jack point at the rear pinch weld and 7.5” ground to jack point at the front pinch weld. Stock springs, 185/65r15 tires.
Hot Rhonda 2008 Toyota Yaris 5dr Liftback - Bayou Blue - Cosmo Racing Short Shifter - Kenwood Single DIN Aftermarket Headunit - Rockford Fosgate Punch 6.5” Speakers “the dents make her handle better.” |
#60 |
I believe the stock 14" tire size is on the left. 175/65/14.
On the right is my hopeful tire size. 215/75/15.
#61 |
The Lift Kit Thread aka The Canadian Commuter mod
Yeah and stock for 15’s is 185/60r15, I’m running a bit of an oversized tire since I got a smokin’ deal on some blizzaks off kijiji.
Have you decided on which tire you’re going to go with? I know a lot of people like the General Grabber AT2s, and I believe they come in a 205/75r15 which is only a 27.1” diameter. I wish BFG still made their super small All Terrain TA KO’s.
#62 |
So you're riding 3/4" higher than a base model cause your wheels are bigger. Need to subtract that from your Jack point height to get a better height estimation
Pretty sure the k02's come in the 215/75/15 size.
#63 |
Yeah they do, they used to make a 195/75r14 for them though. I believe there’s an off-road/dirt Yaris thread on here somewhere and he has them on his Yaris.
I had the 175/65r14s on before the 185/65r15s and noticed that 3/4” for sure once I put them on.
#64 |
Would be good for those not wanting to cut up their car! Lol
#65 |
Update: Approx. 4-500km on the rear lift. All is quiet and the cars ass is still in the air. The spacers look to be a success!
#66 |
![]() ![]() ![]() Drives: 2008 yaris 5dr hatch Join Date: Apr 2016
Sweet. mine has a bit of a clunk with the lifts I put in and I wonder if my shocks are topping out sometimes. May need to put extenders on those. you built that right into the lifts. It's a bit weird driving with just the ass up isn't it.
#67 |
#68 |
Yea, it's substantial. I felt the angle of the seats changed drastically when it was done. Gets a ton of looks too lol
#69 |
You may need to make substantial clearance for that size. For the 27.7" tires I plan to run, gonna need to cut/bend a good portion of rear fender well out of the way, and I'm much more lifted than you are.
#70 |
I expect some trimming and need to pull the fender liners
Sent from my moto e5 play using Tapatalk |
#71 |
We still gotta figure out the fender flare situation lol
#72 |
| Finally bought a lift | CTScott | DIY / Maintenance / Service | 26 | 09-28-2010 09:09 AM |
| zage turbo kit..! just need some help | joseyaris | Forced Induction Forum | 12 | 10-29-2009 08:35 PM |
| Greddy xB kit vs Greddy Fit kit | ellenbetty | Forced Induction Forum | 52 | 09-29-2009 08:42 PM |
| Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast | phu@xenon-vision | Sponsors Classifieds Area | 8 | 03-06-2009 02:33 PM |
