Old 03-25-2019, 10:45 PM   #1
tmontague
tmontague's Avatar
It is quite big, but should fit. I'm actually happy it's large with good cooling capacity since I'll be drawing intake air from behind the engine. I'll get my tape out tomorrow and get the dimensions of the intercooler.
Behind the engine? What intercooler set.up are you doing?
Old 03-25-2019, 10:55 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
I wasn't very clear. When I said "intake air", I meant for the turbo compressor. It's front mount intercooler but the turbo compressor air intake will just be the K&N filter attached directly to the turbo, no cold air intake. I spoke with the guys at TK and the cold air intake - that comes back up from behind the engine and wraps around, placing the filter basically between the engine and battery - is an option. They claim there are many cars with the kit that don't have the cold air intake. The large intercooler looks after any additional heat in the charge piping that might picked up behind the engine. Ultimately, I may come up with my own custom cold air intake. Although theirs is $195.00, it still lands the filter smack dab in the engine bay and up top where the hot air is. If it went somewhere where it could draw colder air, I probably would have bought it. I suppose I could have bought it, another bit of pipe and a coupler and directed it closer to the headlight where the stock airbox is. May do that yet.
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 05:59 AM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-10-2012 12:35 AM
ZPI Turbo for one lucky Yaris owner..... ZPIracing Forced Induction Forum 27 04-26-2007 11:36 PM
