Old 03-26-2019, 08:35 PM   #1
dogsridewith
Drives: 2007 2-door hatchback
Thermostat opening versus temperature curve.
Yes. Higher ambient gives higher coolant and oil temperature. Thermostats, or most thermostats, don't flip from full closed to full open at one temperature. In cold winter, a temperature gets maintained with little coolant flow. So the thermostat isn't very far open. In sweltering heat, the temp may not stabilize until the thermostat is nearly open. And more open takes a higher temperature. The thermostat has an opening versus temperature curve.
And coolant doesn't cool some places so well. The oil pan can be getting radiation and conduction from sub freezing pavement/air or very hot asphalt and the air it heats.
Old 03-26-2019, 09:27 PM   #2
tmontague
tmontague's Avatar
Very much so. In the middle of winter the oil will not go above 180F (give or take a few degrees) unless in a high.load condition. The convection from the oil lan and cold air is much too great to keep the oil at summer operating temps.
On the flip side, in my 2zr with 5w30 full syn oil (factory fill is 0w20) and coolant temps reaching 230F, the oil climbs to just above 280F and stays there until a cool down lap. That is at full WOT and close to redline rpm's though.
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Synthetic VS. Regular oil reliability captainm27 DIY / Maintenance / Service 98 01-20-2010 01:46 PM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
