Old 04-05-2019, 06:28 PM   #1
zoidberg444
zoidberg444's Avatar
If it's attempting to change it sounds like the Solenoid is working fine. That the problem is mechanical, not electrical. These semi-automatic gearboxes are always trouble. Almost sounds like the syncho's aren't gripping and it's having trouble slotting the gears in. In the past before i changed my gearbox oil i noticed it in my own manual transmission car that sometimes you had to have a second go or use a bit more force with the gear change when the car was cold.
What gearbox oil did you put in it? Many people on here have had bad experiences with Mobile gearbox oil. I use a 75W90 GL4 semi synthetic made by Comma. It's pretty cheap but from what i hear these boxes prefer the cheaper dino oil because it allows the syncros to grab better.
- Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles
UK to Nordkapp in a Yaris
Black 07 Plate 1.3 VVT-I Yaris - Need Advice Mattmcc Cosmetic Modifications (Exterior/Interior) 5 10-07-2015 09:29 AM
Yaris 2007 sedan (auto) Transmission fluid change and rear wheel noise DevilzMafia DIY / Maintenance / Service 8 12-24-2012 08:05 AM
Just bought our 2nd Yaris Auto sedan in 20 months MauiDan New YARIS Purchase Forum 11 04-08-2009 02:53 PM
