Old 04-05-2019, 08:49 PM   #1
zoidberg444
zoidberg444's Avatar
Originally Posted by naossoan View Post
Engine squeals when starting, but goes away when I turn interior blower fan off, but it's not the blower that's squealing... I'll replace accessory belt but I have no idea what is causing the squealing.
I had this problem with a DAYCO belt. It wasn't happy whatever the adjustment. So i replaced it with a Chinese "Blue Print" branded one and its been fine for 3 years/80,000 miles. Start your adjustment a little loose, i think the recommendation is about 10-12mm of deflection at the belts longest run.
Rear hatchback lift hydraulics will not push the door open anymore or even hold it open if it's less than halfway open. I can lift it up allthe way and then it will hold it up. Need to replace them.
I think they have gas in them. I hit my head the other week going to get stuff out the boot on a morning because they weren't holding it up. I to think i may replace mine.
Rear hatchback door latch is broken. It doesn't seem to unlock at all. This happened just within the past few weeks. I can hear it clicking in there when I use the keyfob but I am unable to unlatch the door by pushing in the button on the door as per normal. The button pushes in, but the door doesn't open. That button also gets frozen regularly during the winter leaving me unable to open the hatchback.
I have had to remove the inner small panel so I can get at the mechanism with my finger to open the hatchback, which does work, and is currently the only way I can get the hatchback open. I will be ripping this interior panel off soon to get a look at that latch. I think it might be the actuator itself that is pooched, which if that's the case I may be screwed because that thing costs like $350 Canadian to replace. This is by far the most annoying thing I have had to deal with with this car.
This happened to my car a couple years ago. It had been a bad winter with lots of salt on the roads and it was wet and below freezing. I was able to free it up by squirting a shit load of WD40 into it which freed up the mechanism. I think it had some crap and some frozen water inside it. You might be able to find a cheaper part in the scrapyard if it is actually broken.
- Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles
UK to Nordkapp in a Yaris
Consumer Reports Is On Crack!!! doublewam General Yaris / Vitz Discussion 82 05-07-2011 12:03 PM
Florida Yaris Meet! 6/23/2007! Sabretooth Southeast 13 06-05-2007 07:46 PM
