that pulley will always spin, the a/c compressor is not a typical magnetic clutch where you can just look to see if it is engaging or not. I would get a manifold gauge set to see if you have any leaks anywhere.
![]() Drives: 2007 Yaris 4dr Hatch Join Date: Apr 2019
Thanks for that. That’s what I was thinking it was. I might ask around some guys at work about the gauge set to borrow one because for the price it may just be easier taking it into the shop lol.
Proper gauge analysis is certainly a point to start with.
There is no magnetic clutch but a solenoid valve in that compressor that may cause difficulties. The valve can be triggered also with original TechDoc software and cable. Cheap e-bay alternative also worked for me. You may also investigate the pressure sensor, it is easily accessible under the hood and it is a single sensor for both high and low pressures. It changes the resistance values based on the AC pressure. There is a thread here somewhere where I believe ctscott described how to bypass this sensor using two resistors. I had difficulties with that sensor, it gave some strange resistance spikes which confused the control unit and it disengaged the compressor to protect it from damage. I bought the sensor (original Denso) on ebay and got it replaced in the shop (there is a need to evacuate the AC system first). Running cool again. |
