Old 04-09-2019, 02:34 PM   #1
aeipee13
DKDC
aeipee13's Avatar
Drives: Yarlet
Just wanted to dig up this old thread because the Spoon Rigid Collars are the truth. Almost feels like the car has been spot welded. Everything works better suspension-wise and you can really feel it during turns and when you hit an unexpected bump.
I recently added whiteline control arm bushings and had to remove one of the collars but the hardware provided with the whiteline bushings are nearly the same idea. Whiteline tightens up the play between the control arm bushing, bolt, and crossmember using the bushing itself and washers on the top and bottom that have a little lip serving as a "collar" between the bolt hole and the bolt.
I know people call bullshit but think about suspension geometry and all the vibrations and wiggling that goes on. If you still don't understand drive someone's yaris with collars and be amazed.
(dick measuring info goes here)
aeipee13 is offline   Reply With Quote
Old 04-09-2019, 10:08 PM   #2
tmontague
tmontague's Avatar
Where did you order these from?
Old 04-10-2019, 01:37 PM   #3
aeipee13
DKDC
aeipee13's Avatar
Drives: Yarlet
I got mine from RHDjapan but there are plenty on options online. RHDJapan is a grey market importer and they are 100% legit.
Of course you pay for products like this and people will say whatever they want about price but rigid collars are worth it. I've been using mine for over 2 years now and have no issue other than being faster in turns.
I am firm believer if an upgrade makes the driver more confident and happier behind the wheel, F@*k whatever anyone else thinks.
FS: Full NCP91 KavinT Manseth Kit (Front Bumper has Damage) Treyz Items for Sale by private party 22 04-08-2014 06:17 PM
RZCrew Garage Rigid Collars Chuckie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 02-13-2014 12:34 AM
SilkRoad NCP91 Coilovers In-Stock! Penguin Garage Penguin Garage 28 07-12-2009 05:48 PM
