If it is a misfire due to ignition, you would have a CEL and therefore a code to read. Without it I would guess fuel issue although not common on the yaris
#2 | |
![]() Drives: 2008 Yaris Manual Join Date: Apr 2019
I may just get some plugs, and 1 coil pack, and rotate it through each cylinder. If it doesn't solve the problem, I'm just going to dump it for like 2k. Otherwise, I'll end up spending 100's on labour on a car selling for less than 3k. Also this only occurs once the car has been driving for like ~10 mins. Does that sound like a fuel pump? |
#3 | |
And no, of course nothing with cars is going to be 100%, there will always be outliers. But how will a bad coil pack cause a huge misfire to where the car wont even accelerate but somehow doesnt trigger a single cylinder or multiple cylinder misfire code? Typically it will throw a single cylinder code as well as a multiple cylinder misfire code. Up to you where you want to put the money but it can get expensive throwing parts at it and seeing what sticks. Have you ever actually hooked a scanner up to the car or are you just basing it off of not seeing a CEL? Does the CEL momentarily illuminate when you turn the car on? The catalytic converter is also a potential cause of your issues. If people tell you to start replacing parts without knowing what is wrong in the first place walk away very slowly... If you do get it figured out, let us know then issue
