Old 04-13-2019, 04:38 PM   #1
tmontague
tmontague's Avatar
Originally Posted by 2bz View Post
The lube used is GL4 75W. That's essentially the Toyota spec. Should be ok
Is it a straight 75w oil though? If so then it is too thin at operating temps
Old 04-14-2019, 01:06 PM   #2
kivig
Drives: 2SZ-FE, 5MTM, 2008 TMMF
The idea was, as suggested manyplace on this forum with mostly positive feedback for situations like this, to use the thinnest oil allowable, to increase ability of synchros to pierce it.
And even with that - as described - it's not even close to enough when below 0C - then I have to carefully push it for a solid second or more to avoid gear grind or just floor it and skip to 3rd and then 5th.
It's better at moment as it is warmer (maybe due to new synchro too to some limited extent), but the realization that it still skips a tooth or two, slowly filing the gear away every time I flick the knob a bit faster in traffic is not something I'm used to tolerating when it comes to machinery.
Starting to lean towards finding another gearbox and replacing most of it.
kivig is offline   Reply With Quote
P0705: Yaris 2008 stuck in first gear in D position eepp DIY / Maintenance / Service 3 01-22-2018 12:24 PM
My Car Shakes Noticebly when I Put The Gear into Reverse When The Car Is on a Slope Meteorite2 DIY / Maintenance / Service 3 11-14-2014 06:56 AM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 12:51 PM
Reverse gear crunch Frankd1 DIY / Maintenance / Service 5 04-13-2009 01:43 PM
