Old 04-15-2019, 07:30 PM   #1
myfirstyota
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped
Its the learning process you crave. Much like many of us, I bet its the challenge you enjoy.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61427
Bolt-in 3.75" Suspension Lift Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61577
myfirstyota is offline   Reply With Quote
Old 04-15-2019, 09:22 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
For sure, myfirstyota. I have to constantly fight the urge to rush things/take shortcuts. That said, a lot of aspects of the project are compromises.
I was out investigating how the heater hoses will play with my planned intake. It looks as though it will work with the trickiest part being getting the 3" piping down between the block side heater port and rad hose. I may need to splice in a coupler there for flexibility. Since I'm having to cut the heater hoses to attach to the turbo, I can then rotate the cut pipe ends out of the way. I'll also need to shave about 3/8" off the plastic battery tray. Interestingly, I had an old R134 A/C refrigerant can lying around and it's precisely 3" in diameter. I used it to test clearance for the 3" intake pipes. Worked like a charm. There is one cast tab on the head at the back of the motor that will need to be ground down slightly, as well as the removal of a steel bracket that I think was used for a harness support. I'll also have to slightly bend the transmission dipstick tube and overflow tube a bit out of the way. Other than that, it looks like a reasonably clear path.
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-09-2012 11:35 PM
ZPI Turbo for one lucky Yaris owner..... ZPIracing Forced Induction Forum 27 04-26-2007 10:36 PM
