![]() Drives: 2SZ-FE, 5MTM, 2008 TMMF Join Date: Oct 2017
Yesterday I replaced oil with Toyota LV 75W. There might be some minor effect due to it's viscosity being a few percent lower (or it just got warmer outside), but still - second gear synchro isn't capable of grabbing the shaft fast enough, skipping teeth in about 25-30% of gear changes and the rest of gears are struggling.
Probably will have to look for a used gearbox for parts still. Any idea what should be replaced? Then again - is there any way to positively test whether the clutch is not dragging? Bell housing has a convenient ventilation hole (rectangle rubber water protector that can be taken out) to stick a camera in. Unfortunately the spring plates and release bearing obstruct the view of shaft rotation. Last edited by kivig; 04-17-2019 at 05:42 AM. |
| P0705: Yaris 2008 stuck in first gear in D position | eepp | DIY / Maintenance / Service | 3 | 01-22-2018 12:24 PM |
| My Car Shakes Noticebly when I Put The Gear into Reverse When The Car Is on a Slope | Meteorite2 | DIY / Maintenance / Service | 3 | 11-14-2014 06:56 AM |
| Gear oil change choices (Canadians) | Jem_hadar | DIY / Maintenance / Service | 17 | 08-29-2009 12:51 PM |
| Reverse gear crunch | Frankd1 | DIY / Maintenance / Service | 5 | 04-13-2009 01:43 PM |
