Looking good man, keep it up!
Thanks, Trevor. I appreciate it. It's a fun project.
A question for ya... You put a sandwich plate in after you upgraded to the screw-on filter mount, correct? Did you install an oil cooler?
#3 | |
I did not install a cooler however, there should be enough space in that area for oil lines you will just have to figure out a way to strap the lines secure as they run out to the cooler. They will technically run alongside the bottom end of the block.
#4 | |
How are you monitoring oil temps? Did you put a sensor in your sandwich plate? Unfortunately, Torque doesn't have access to that PID. I am definitely installing a transmission cooler, but am on the fence about an oil cooler at this point.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 04-28-2019 at 09:07 AM. |
| 3rd gen 2zr swap with 6 speed | stidnam | Performance Modifications | 97 | 06-29-2021 04:59 AM |
| Hyundai Turbo Veloster 150kw | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 6 | 01-09-2012 11:35 PM |
| ZPI Turbo for one lucky Yaris owner..... | ZPIracing | Forced Induction Forum | 27 | 04-26-2007 10:36 PM |
