Old 04-27-2019, 06:42 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by tmontague View Post
Looking good man, keep it up!
Thanks, Trevor. I appreciate it. It's a fun project.
A question for ya... You put a sandwich plate in after you upgraded to the screw-on filter mount, correct? Did you install an oil cooler?
Old 04-27-2019, 08:39 PM   #2
tmontague
tmontague's Avatar
correct, this was the primary reason for my screw on filter mount upgrade.
I did not install a cooler however, there should be enough space in that area for oil lines you will just have to figure out a way to strap the lines secure as they run out to the cooler. They will technically run alongside the bottom end of the block.
Old 04-28-2019, 08:36 AM   #3
06YarisRS
Thanks. I had read that many of the sandwich plates would not fit due to proximity to the block, but obviously that's not true. There must be narrow ones available that have a small enough diameter to fit. Secondly, I'm thinking it might be a good idea to have an oil cooler, or minimally, at least initially, monitor oil temps. I was speaking to one of my son's hockey teammate's fathers who has built a number of performance cars, and he said that, in no uncertain terms, I should have an oil cooler. I hadn't mentioned to him that the turbo is water cooled, so that should make a difference. A cooler would also provide a little addditional oil in the system to aid in cooling.
How are you monitoring oil temps? Did you put a sensor in your sandwich plate? Unfortunately, Torque doesn't have access to that PID.
I am definitely installing a transmission cooler, but am on the fence about an oil cooler at this point.
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-09-2012 11:35 PM
ZPI Turbo for one lucky Yaris owner..... ZPIracing Forced Induction Forum 27 04-26-2007 10:36 PM
