![]() Drives: Toyota Yaris SEdan Join Date: Oct 2016
parking brake light on & abs light on ! car stuck in 2nd gear !!!
mine is an Automatic 2007 yaris, today i was driving home....suddenly the parking brake light & abs light came on, and transmission is not shifting gears, its stuck on 2nd gear. I've checked.....all the fuses, they are fine......what could be the reason
You need to get codes read.
#4 | |
![]() ![]() Drives: Yaris 2016 1.3 Manual Join Date: Jun 2017
just pair it with your phone then you need to run some aps like torque or other apps that can scan and read error codes and the error code/s will pop up for you to make a start of your diagnosis. |
| HELP! ABS & BRAKE LIGHT ON SIMULTANEOUSLY! | mizhgolightly | DIY / Maintenance / Service | 45 | 05-03-2022 02:59 PM |
| ABS BRAKE light FIX sedan | IndestructibleYaris | DIY / Maintenance / Service | 4 | 11-27-2021 01:35 PM |
| My Car Shakes Noticebly when I Put The Gear into Reverse When The Car Is on a Slope | Meteorite2 | DIY / Maintenance / Service | 3 | 11-14-2014 05:56 AM |
| Car got stuck in gear? | mr_miles | DIY / Maintenance / Service | 1 | 03-24-2012 11:25 AM |
| ABS LIGHT & E BRAKE LIGHT | rossman | DIY / Maintenance / Service | 5 | 02-25-2010 11:09 PM |
