Old 05-01-2019, 04:36 PM   #1
TypeReaL
Drives: 2006 Yaris Hatch
After much heat and removal of the axle which ill tell you the mess with that I did manage to get it out and remove the o2 sensor which seemed to be cross threaded into the stock manifold as if to prevent reuse could be crazy but i doubt its ever been off.
Now when the axle nut came about half way The impact went from full spin to wow thats spinning slow come to find the threads stripped and right near the splines you could see where it turned blue from being so hot but all and all everything goes back in tomorrow when the parts store has the new o2 thanks for all the help fellow yaris enthusiasts ! now the header is done there is more to come :D
TypeReaL is offline   Reply With Quote
FS: Tanabe Medallion axle-back exhaust Samantha0716C Items for Sale by private party 11 06-15-2018 10:16 AM
Please help with exhaust 06YarisRS DIY / Maintenance / Service 10 10-03-2017 12:04 PM
Exhaust Manifold to Pipe Donut Gasket yarisinpa DIY / Maintenance / Service 1 06-29-2017 03:35 AM
Exhaust manifold damaged by corrosion donpalino DIY / Maintenance / Service 5 05-26-2015 04:38 PM
yaris voltage issue yaris2010RS DIY / Maintenance / Service 11 12-29-2012 04:20 PM
