Old 05-08-2019, 02:13 PM   #1
Mike Dexter
Drives: '10 Hatchback
See the crack in the paint just behind the clip? That crack likely goes through the sealer that covers the welded joint at the roof edges.
Get a tube of body sealer from an auto parts store, and brush it all over the bottom of the trench. Silicone dries and cracks over time...found that out the hard way.
I can't tell from your 3rd photo - does that large circular hole allow you to get at the clip's bolt/nut from the underside? If you can, remove that clip, and seal under it too. If not, reach through and brush sealer from underneath.
Mike Dexter is offline   Reply With Quote
Leaking rear wheel cylinders? xdarkxfirex DIY / Maintenance / Service 8 04-11-2017 02:47 PM
Chrome pillar trim for 3 dr Foot Cosmetic Modifications (Exterior/Interior) 3 01-26-2013 04:09 PM
Water Leaking into car! CKaelin General Yaris / Vitz Discussion 18 08-16-2012 01:53 AM
Axle seals leaking caused by lowering ride height? NH3R717 DIY / Maintenance / Service 2 07-22-2010 03:29 PM
Fishing an AV wire down B pillar redyaris In Car Entertainment + Electronics (audio / video / alarm) 6 03-10-2007 06:17 PM
