![]() ![]() Drives: 2007 Toyota Yaris 3dr Join Date: Aug 2017
I have the same exact issue. I will pull out the molding an apply the black body sealer as well.
The Gibbs Garage 2016 Lexus GS350 f-sport (my main car) 2013 Lexus RX350 (wife's vehicle) 2010 Toyota Tacoma (my second vehicle) |
#2 | |
![]() Drives: 2007 Yaris Coupe Join Date: Aug 2016
Kind of obvious problem at 70 MPH and something slapping the back of the car. I ripped them off and now I've got tiny leak at A Pillar just above me, The Driver. I'm going to look into this Body Filler Stuff. I was just going to silicone over the holes that cannot be seen until I get it properly fixed. I guess "Body Filler" IS Bondo? That would not be the thing to do if one ever wanted to fix it Right. Body Man.....OK. DIY...No. I guess what is Right to some is different for others. Last edited by ct77414; 05-27-2019 at 08:48 AM. |
#3 | |
![]() Drives: 2008 Toyota Yaris Join Date: Feb 2019
I wanted to test covering potential points where the water is leaking in with the silicone I had before I went ahead and got seam sealer, removed the silicone, and really covered things in a durable way. I covered everything up that looked like a crack in the gutter and the leak didn't go away. That's when I started looking for other places the water could be coming in. Eventually I put silicone across almost the entire width of the car where the windshield meets the roof. This finally killed the leak...so far. A picture of my terrible handiwork is attached. |
| Leaking rear wheel cylinders? | xdarkxfirex | DIY / Maintenance / Service | 8 | 04-11-2017 02:47 PM |
| Chrome pillar trim for 3 dr | Foot | Cosmetic Modifications (Exterior/Interior) | 3 | 01-26-2013 04:09 PM |
| Water Leaking into car! | CKaelin | General Yaris / Vitz Discussion | 18 | 08-16-2012 01:53 AM |
| Axle seals leaking caused by lowering ride height? | NH3R717 | DIY / Maintenance / Service | 2 | 07-22-2010 03:29 PM |
| Fishing an AV wire down B pillar | redyaris | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-10-2007 06:17 PM |
