Old 05-14-2019, 06:15 AM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Haha, very cool and creative. One thing I've noticed is that virtually every adaptation/mod I have done related to my turbo build has been do-able because of the way the Yaris is designed. I always seem to have just enough space (with slight modifications), always have some convenient place to anchor stuff too etc. I can definitely say that I got lucky a few times.
Do you have any concerns about vibrations causing cracking in the plastic headlight body? The headlights do seem quite robust, however. I do like where your filter is placed. I'd have mine there too if it weren't already occupied by the charge piping.
Old 05-14-2019, 10:39 AM   #2
tmontague
tmontague's Avatar
I agree, for such a small engine bay/front end, there is a decent enough amount of room in there. Have you ever seen the engine bay of a Mini S, they give me anxiety just looking at them!
The intake and filter is no longer touching the headlight housing since I installed my bracket. There should be any contact even with bumps so there should be no issue of cracking. The original bracket supplied by DC is rubber dampened but my bracket is not, potentially my bracket could crack but it seems very stable and the intake is not overly heavy so it should be fine
Old 05-15-2019, 06:04 AM   #3
06YarisRS
Actually, yes, I did have the chance to peek into the engine bay of a Cooper S. One of my colleagues bought a 2014 recently. Yep, pretty tight in there for sure. My bay, by comparison, looks quite airy. It makes me feel a touch better about engine bay temps. His Cooper is the Countryman AWD, I believe. We went for a little spin and he was kind enough to let me drive. To be honest, I was expecting a bit more uumph. I'm pretty sure my 3.5L powered Sedona minivan would walk all over it. I expect that the regular, lighter Cooper S FWD would be more impressive.
I didn't realize that your mount was not on the headlight housing. Sounds like you've got a great solution there.
Old 05-15-2019, 12:21 PM   #4
tmontague
tmontague's Avatar
The first gen Mini S's used to ride on the bump stops they were so harsh - handles like go carts but tough to daily. The second gen's they smoothed it out quite a bit and made it much more refined. They are definitely a blast to drive but as usual they suffer from carbon build up on the intake valves badly and trying to do anything in that engine bay is a disaster.
The intake mounts to a bolt hole with a bolt that grounds the headlight harness just in front of the headlight. That is where the original DC intake mount bolted to
Old 05-16-2019, 05:27 AM   #5
06YarisRS
Interesting. Yeah, I can't see the majority of the consumers liking a harsh ride regardless of how well it handled. I guess the manufacturers feel that the public is willing to sacrafice handling for a more tempered ride. I too can say that I appreciate a nice balance between handling and a smooth/comfortable ride.
I'm guessing that they are DI if they are suffering the intake coking. And, yes, they''re pretty cramped in the engine bay from what I've seen.
Sounds like your intake is 'track-ready' now. We plan to be in Toronto again this summer, though haven't set hard dates. Maybe it will correspond with one of your track days. I bet my son would love to see that, haha.
Old 05-17-2019, 08:08 PM   #6
tmontague
tmontague's Avatar
That would be great to meet up at the track, we should try and coordinate something
Yup, the mini's are DI and have some serious intake valve issues, my in-laws have had a first and second gen mini S so that is why I've been able to drive both.
I agree with you on the handling for a DD, too stiff and it becomes no fun every day. For a track car on the other hand, it will drive pretty rough on public roads if it is set up properly for the track. I am still blown away how stable and flat my car is under severe cornering. It also drives fairly rough and gets taxing being a DDer
Need 07 Sedan Tail Light wiring info ASAP atebit General Yaris / Vitz Discussion 3 09-07-2013 06:48 PM
Swap sedan tach into liftback GrassrootsMS DIY / Maintenance / Service 17 09-26-2007 09:45 AM
thinking about buying the sedan. is it worth the extra money for the s(optB) version? friedbbq General Yaris / Vitz Discussion 14 05-20-2006 12:53 PM
