#1 | |
The intake and filter is no longer touching the headlight housing since I installed my bracket. There should be any contact even with bumps so there should be no issue of cracking. The original bracket supplied by DC is rubber dampened but my bracket is not, potentially my bracket could crack but it seems very stable and the intake is not overly heavy so it should be fine
#2 | |
I didn't realize that your mount was not on the headlight housing. Sounds like you've got a great solution there.
#3 | |
The intake mounts to a bolt hole with a bolt that grounds the headlight harness just in front of the headlight. That is where the original DC intake mount bolted to
#4 | |
I'm guessing that they are DI if they are suffering the intake coking. And, yes, they''re pretty cramped in the engine bay from what I've seen. Sounds like your intake is 'track-ready' now. We plan to be in Toronto again this summer, though haven't set hard dates. Maybe it will correspond with one of your track days. I bet my son would love to see that, haha.
#5 | |
Yup, the mini's are DI and have some serious intake valve issues, my in-laws have had a first and second gen mini S so that is why I've been able to drive both. I agree with you on the handling for a DD, too stiff and it becomes no fun every day. For a track car on the other hand, it will drive pretty rough on public roads if it is set up properly for the track. I am still blown away how stable and flat my car is under severe cornering. It also drives fairly rough and gets taxing being a DDer
| Need 07 Sedan Tail Light wiring info ASAP | atebit | General Yaris / Vitz Discussion | 3 | 09-07-2013 06:48 PM |
| Swap sedan tach into liftback | GrassrootsMS | DIY / Maintenance / Service | 17 | 09-26-2007 09:45 AM |
| thinking about buying the sedan. is it worth the extra money for the s(optB) version? | friedbbq | General Yaris / Vitz Discussion | 14 | 05-20-2006 12:53 PM |
