Found it:
http://jdmfsm.info/Auto/Japan/Toyota...als/index.html Also: https://cardiagn.com/2007-toyota-yar...r-manuals-pdf/ I was able to download the first link. The second link would let me view online but not download. FYI even though this is a manual for a second generation car most info is applicable to 3rd gen as well. |
#2 | |
![]() ![]() Drives: Yaris 2008 Sedan Join Date: Nov 2010
However, I did find a spec sheet that shows you how to determine the torque for all bolts based on their size and pitch, so I'll be using that in the future for any other mystery bolts. Edit: I went with the following parts DEA A4254, Westar EM-5930, DEA A4237, and 12364-21020 from Toyotapartsdeal which I believe is supposed to be OEM. I just wasn't ready to drop OEM money for something that many not be a sure fix. Had this issue with my old yaris and did all mounts twice with OEM from tpd and it never was resolved. If I see a difference, I'll fork the money when these go out. I haven't heard or seen Ori. I'll check them out, thanks! Edit2: while putting my back seats frame bar back on, I realized the bolts used had a torque spec of 125Nm on the doc I mentioned, after some testing, I determined that those bolts were actually 42Nm (same as the seat belt bolts.) Just thought I'd mention it in case someone else makes the same assumption I did. Last edited by seatech30; 05-17-2019 at 04:04 PM. |
#3 | |
![]() Drives: Toyota Yars Join Date: Jun 2017
I just tried to change this lower engine moving control rod and bracket, but I couldn't get to that one hard to reach bolt. |
| Torque Specs 2009 Suspension | GrayYaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 04-22-2014 11:04 PM |
| looking for torque specs on front caliper bolts 07 yaris | mikee07 | DIY / Maintenance / Service | 2 | 10-21-2012 03:36 PM |
| torque for wheel bolts? | caineroad | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 05-13-2012 08:07 PM |
| Suspension Torque Specs pls | nisyota | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 12-21-2010 07:04 AM |
| Tighten bolts to factory specs? | marlondog | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 10-19-2010 05:18 PM |
