#1 | |
That breather hose that normally see's vacuum and now is vented to atmosphere do you foresee any issues with that? I've read varying things online about removing the vacuum from breather hoses potentially causing problems in a system designed for vacuum. That said I would think you should be perfectly fine seeing as that hose is upstream of the TB and therefore doesn't actually see much vacuum at all. It would see minimal vacuum at idle and during WOT there is little vacuum anyways
#2 | |
The other thing I had wondered about is the brake booster under boost. I guess there is a check valve in that system that will prevent boost going back to the brake booster.
| 3rd gen 2zr swap with 6 speed | stidnam | Performance Modifications | 97 | 06-29-2021 04:59 AM |
| Hyundai Turbo Veloster 150kw | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 6 | 01-09-2012 11:35 PM |
| ZPI Turbo for one lucky Yaris owner..... | ZPIracing | Forced Induction Forum | 27 | 04-26-2007 10:36 PM |
