Reviving this thread as this just happened to me and I'd rather keep related information all in one thread as opposed to spread out all over the place. Makes it easier for those searching for specific info.
Some additional info: The bolt in the rear cup holder is 10mm. You need a somewhat long extension to get it. I used a 10" extension. Once the bolt is removed lift up the console from the rear. It moves fairly easily but gets tight between the seats. Before totally removing the console you need to remove the drop in panel where the traction control switch is located. It is just held on by a couple of tabs. I was able to wiggle it loose just with my hands. After that unplug the connector going to the TCS switch. Now you can totally remove the shift console. Next remove the shift indicator panel. It is held on by 4 tabs (2 on drivers side, 2 on passengers side). Again this can be done by hand, but if you are having trouble I recommend using a plastic trim removal tool. Once loose just rotate it out of the way and you will see the bulb. There is no need to totally remove it but if you want to you will need to remove the shift knob. It is threaded onto the shaft. Just unscrew it. The bulb just pulls straight out. It is not screwed in. There is a flexible plastic sheath over the bulb. Roll it off like a condom and then onto the new bulb. As CTScott said the Toyota part number is 35955-74010, but I used a Sylvania #74 bulb. For less than the price of one at Toyota I was able to get two at AutoZone. That said the #74 bulb is slightly fatter and the base is just a hair wider (and I mean just) than the official Toyota bulb. It fits in the socket but you may have a problem making good electrical contact. I did. I plugged it in, turned on the lights and nothing. Tried the other bulb and again no light. WTF. Got out the old multimeter, tested both bulbs for continuity, both OK. Tested old bulb, NG. Hmm...set it on DC volts, turned on lights, tested socket...12V. WTF. So I plugged one of the new bulbs back in and started wiggling it about, it lit up momentarily but wouldn't stay on. Here's the trick if this happens to you. Take the two bare wires running on either side of the bulb and bend them every so slightly away from the bulb body. They are stiff enough that they will act like a spring inside the socket, holding it in place and ensuring good electrical contact. Just make sure you have the bulb fully seated. That's it. Put everything back opposite order you took them off and be sure to test the bulb and the TCS switch before you button everything up. All told this took me about 15 minutes and that includes my troubleshooting efforts. Would be even quicker assuming no problems. While searching the net for info on how to do this I came across a post in a Prius forum where Toyota charged someone $140 to replace this bulb on a Prius C. (Shifter, console, bulb, etc. is the same as Yaris.) Insane! Follow these instructions and save yourself $135. And yes, I know, I should have taken pictures. I always remember after the fact, but I'm one of those old farts who grew up without a camera in my pocket 24/7. It's a different mindset. Last edited by NYC-SE; 05-21-2019 at 05:06 PM. |
| The MI SSK "Not a Big 'Car Guy'" Review | jpmck03 | Performance Modifications | 36 | 09-19-2013 11:41 PM |
| Original tail light without rear fog light for Yaris 3dr 2009-2011 | Ot_tO | Cosmetic Modifications (Exterior/Interior) | 9 | 08-07-2012 04:27 PM |
| 06-10 Yaris Sedan cold air intake $40 | kylevh21 | Items for Sale by private party | 2 | 04-01-2012 02:14 PM |
