Old 05-23-2019, 10:47 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
F/IC Wiring
I started looking at diagrams again tonight in anticipation of wiring the F/IC. Tonight's search was for a switched power source at the ECU for the F/IC power supply. Pin 28 on A21 did indeed prove to be a reliable source. I tested it and it is indeed a switched 12V source. So, that's good. I will find the signal grounds tomorrow. Since this configuration of a 2008 xD ECU, 2011 harness and 2ZR engine is unfamiliar to the turbokits guys and AEM, it will be an experiment for sure.
I had a bit of a scare. I wanted to test my trans fan and relay by crossing the terminals on the trans thermostat sensor. It seemed that my EFI fuse socket (the one that powers the MAF - thanks Trevor for that one - and now also the power supply for the transmission temp thermostat) had lost power. I tested it numerous times and started to get a little depressed. I went back inside and started pouring over the wiring diagrams hoping to find another fuse somewhere that, if blown, would cut the power supply. It turns out that because I still had the right ECU connector (A21) disconnected, the circuit was incomplete. I plugged it back in and voila, power was restored. MAF has switched power and the relay for the fan works great too.
Here is what had me freaked out before I discovered what was wrong.
Old 05-24-2019, 12:51 PM   #2
tmontague
tmontague's Avatar
F/IC Wiring
Glad to hear you found the source of your electrical scare. I've had a few issues like that in the past where it ended up being a simple thing and for a couple hours the panic sets in. Keep the posts coming!
Old 05-24-2019, 09:41 PM   #3
06YarisRS
Haha, yeah, it had me going for a bit. One thing about doing a build and documenting it, is that you know everything that you've done, so the proposition of fixing something doesn't seem as daunting as if you simply adopted a vehicle with so many mods. Still, though, no doubt I'll be scratching my head when it comes to start-up day and it doesn't start. LOL.
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-09-2012 11:35 PM
ZPI Turbo for one lucky Yaris owner..... ZPIracing Forced Induction Forum 27 04-26-2007 10:36 PM
