Old 05-27-2019, 04:52 AM   #1
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
FWIW
I ran carbotechs on my track car and barely got 1 weekend out of them. Which is abosurd for the $180~ i paid for them. Called them up and they of course didnt take any of the blame for a crap product and said something was wrong with my car. I switched to Porterfields and finished the year off (3 more weekends) and still had life left in them and I liked the dynamics better.
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 05-27-2019, 07:48 AM   #2
tmontague
tmontague's Avatar
Originally Posted by malibuguy View Post
FWIW
Based on the low price of $180 I'm assuming you were running a pad not rated for the track driving you were doing?
I have about 250km of track driving on my xp10 pads and they are probably around 50-60% left
Old 06-01-2019, 07:54 PM   #3
malibuguy
Obsessed with 1.5L
they sold me the xp10s which I believe is a track dedicated pad, but ok enough to drive to and from the track.
with that car I had a dedicated street pads with matched rotors, and then track pads with matched rotors. Basically when I have a track weekend coming up, Id usually swap the track stuff over a few days prior and bleed the brakes and then I make sure everything works on very spirited touge run (they did throw sparks which was kinda cool) then pack up and head to the track. With any NEW track pad, I go thru a multi evening, highway high speed (over 2wice the speed limit), multi-step bed in process. That car would do 120 on the main straight and throw the anchor out for a 45~ right hook. I NEEDED my brakes to work ;)
the only reason I went with them as all my other track buddies with similar sized cars swore by them. Well I dunno. I used the same calipers as with the poterfields, got new discs to dedicate to them and never looked back. Treated them to the same exact bed in procedure.
now days I dont have the same income vs cost of living delta as I used to. so I only do smaller track events or the occasional autoX
-96 Tercel 4dr
Old 06-03-2019, 12:37 PM   #4
tmontague
tmontague's Avatar
hmm, this is interesting feedback as your set up is virtually identical to mine. I use xp10's with dedicated rotors that I swap on and off prior to track day. The only real difference is how I bed my pads in. I sort of skipped Carbotech's procedure and did a similar version that Hawk recommends (due to the CT procedure not being realistic for me on the street). This involved doing a bunch (10 or so) of fast slow downs from about 70km/h to 20km/h and then once that was completed I did about 5 full stops from 90km/h to zero.
Eventually I could smell the brake pads and I could feel the friction increase. Drove it back home using minimal brakes and parked it for the night before I went to the track the next day. The only issue I have had with the xp10's is a slight crumbling on the edges of the pad and what appears to be surface cracks. I emailed CT and they explained that I am likely exceeding the temps of the pads and to increase to xp12 which I will be trying once my 10's wear out.
My local track is similar to your situation just slightly less speed it seems. It involves about 150km/h into a sharp 75 degree corner where I scrub down to about 100km/h within a short braking zone. There is another one of these right after and then a handful of slightly lower speed but really hard braking zones. It is a track that isn't easy on brakes typically.
Thanks for your heads up, it's good to know
Old 06-03-2019, 09:39 PM   #5
malibuguy
Obsessed with 1.5L
It very well could of been anomaly.
So with new track pads Ill usually do like 4-6 moderate stops from 60mph to like 10, then i do another set progressively harder...maybe take it up to around 70-80mph. Take it easy for a few miles then start the high speed stuff. 2-3 HARD stops from north of 100mph.
Luckily not too far away from where I used to live is a divided expressway thats pretty quiet late at night with no cops so I can get away with this without noone near me.
Street pads I do the same process minus the latter, triple digit stuff.
The car was a turbo tercel that weighed 2080 with me in it on NT01 tires.
It wasnt too fast, i ran similar times to midpack Spec Miatas on Summit Main and would easily hand gt86s their ass. Pretty much all I cared about haha
-96 Tercel 4dr
hawk performance pad non-availability explained dsc_pat Performance Modifications 6 09-23-2007 11:58 AM
