Old 05-31-2019, 02:04 PM   #1
RMcG
Drives: Yaris manufactured after 2007
Originally Posted by tmontague View Post
Do it yourself in the parking lot - here's how:
close the pet cock and re fill with fresh Toyota coolant (50/50 mix) from the rad cap.
Thanks tmontague for the detailed instructions and the encouragement. I plan to do it myself. It's not just the money, it's --- it's ---- it's, well it's being human.
ONE QUESTION: you say re fill with fresh Toyota coolant. Does that mean I should use a special Toyota brand coolant?
I added to my last post that the car is almost 11 years (131 months), whereas the maintenance schedule recommends a change at 120 months (10 years). But I checked the coolant and it appears pink and clear without particulates. And the level is about 1 inch above the "LOW" line on the plastic overflow container. So I think I am OK to wait until I get back from the trip.
Any more comments will be appreciated.
Thanks,
R.
RMcG is offline   Reply With Quote
Old 05-31-2019, 02:12 PM   #2
tmontague
tmontague's Avatar
Thanks,
R.
Most of us YW member recommend Toyota brand coolant instead of other aftermarket brands. That being said, full disclosure - Toyota coolant here is only found in 50/50 mix and is not cheap. I found a company (Recochem) that makes various coolant for all different type of manufacturers and the name they brand it with is "OEM". It is sold locally to me and I can buy a pure concentrate that I mix myself with deionized water. I looked up the MSDS and the ingredient are essentially the same as Toyota's. I go with this instead of Toyota's own coolant and it has worked wonderfully for me.
I would recommend you look at getting Toyota stuff and if it is reasonably priced than stick with that.
Like I said before, you will be fine to do the coolant change after your trip. I doubt the corrosion inhibitors are fully depleted. If they were, driving isn't the issue, worn out coolant will eat away at your engine block regardless of driving or sitting in a driveway. Dip your fingers in the coolant and rub them back and forth, it should feel somewhat slippery.
Old 06-27-2019, 04:49 PM   #3
RMcG
An undiluted OEM Reochem coolant (that is for Toyota, and is compatible with the Yaris according to the website) is sold through Rock Auto, see RECOCHEM 86174POEM
I may buy this as I want to depress the freezing point more than -34 Fahrenheit, and it is also cheaper than the standard pre-diluted Toyota brand 00272-SLLC2 (I think is the correct number). Some websites like Amazon, Ebay and ToyotaPartsDeal.com sell the older undiluted coolant 00272-1LLAC-01 and some Toyota dealerships in cold parts of the US (e.g., Alaska) still stock this older undiluted (00272-1LLAC-01) coolant. These dealerships dilute the 00272-1LLAC-01 coolant 60/40 (coolant/distilled water) to get a freezing point of minus 56 Fahrenheit.
QUESTION: Does anybody have any opinion about whether the (apparently newer) Reochem would be better than the (apparently older) Toyota brand 00272-1LLAC-01 ? They are both undiluted and are about the same price.
Thanks,
R.
Tags
change, coolant, engine
AT fluid change earlier than 100k miles hw6515 DIY / Maintenance / Service 25 06-06-2014 01:54 PM
HELP! Coolant is rusty brown only 30K! TheSilkySmooth DIY / Maintenance / Service 25 05-27-2010 08:26 AM
