#1 | |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
with that car I had a dedicated street pads with matched rotors, and then track pads with matched rotors. Basically when I have a track weekend coming up, Id usually swap the track stuff over a few days prior and bleed the brakes and then I make sure everything works on very spirited touge run (they did throw sparks which was kinda cool) then pack up and head to the track. With any NEW track pad, I go thru a multi evening, highway high speed (over 2wice the speed limit), multi-step bed in process. That car would do 120 on the main straight and throw the anchor out for a 45~ right hook. I NEEDED my brakes to work ;) the only reason I went with them as all my other track buddies with similar sized cars swore by them. Well I dunno. I used the same calipers as with the poterfields, got new discs to dedicate to them and never looked back. Treated them to the same exact bed in procedure. now days I dont have the same income vs cost of living delta as I used to. so I only do smaller track events or the occasional autoX
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#2 | |
Eventually I could smell the brake pads and I could feel the friction increase. Drove it back home using minimal brakes and parked it for the night before I went to the track the next day. The only issue I have had with the xp10's is a slight crumbling on the edges of the pad and what appears to be surface cracks. I emailed CT and they explained that I am likely exceeding the temps of the pads and to increase to xp12 which I will be trying once my 10's wear out. My local track is similar to your situation just slightly less speed it seems. It involves about 150km/h into a sharp 75 degree corner where I scrub down to about 100km/h within a short braking zone. There is another one of these right after and then a handful of slightly lower speed but really hard braking zones. It is a track that isn't easy on brakes typically. Thanks for your heads up, it's good to know
Obsessed with 1.5L
It very well could of been anomaly.
So with new track pads Ill usually do like 4-6 moderate stops from 60mph to like 10, then i do another set progressively harder...maybe take it up to around 70-80mph. Take it easy for a few miles then start the high speed stuff. 2-3 HARD stops from north of 100mph. Luckily not too far away from where I used to live is a divided expressway thats pretty quiet late at night with no cops so I can get away with this without noone near me. Street pads I do the same process minus the latter, triple digit stuff. The car was a turbo tercel that weighed 2080 with me in it on NT01 tires. It wasnt too fast, i ran similar times to midpack Spec Miatas on Summit Main and would easily hand gt86s their ass. Pretty much all I cared about haha
| hawk performance pad non-availability explained | dsc_pat | Performance Modifications | 6 | 09-23-2007 11:58 AM |
