Old 06-24-2019, 10:06 PM   #1
tmontague
tmontague's Avatar
You dont need to drain the oil as it is located in tje head and tje head doesn't hold any oil when the car is sitting there with the engine off.
As long as you use a pry bar or punch from tje correct spot it won't fall apart. It is hard to explain bit the actual external portion of the actuator or held on to a metal ring with 4 claws that are bent around it. As long as you push/pry on the metal part and not the plastic that tje claws attach to then it should wiggle out - don't just grab it and pull
Old 06-25-2019, 12:45 AM   #2
seatech30
Drives: Yaris 2008 Sedan
Sweet, thanks! I think I understand what you're describing.
seatech30 is offline   Reply With Quote
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
