![]() ![]() ![]() Drives: Yaris 06 - 5dr hatchback Join Date: Aug 2015
I cleaned mine when i did my last oil change. I doubt there would be any oil in it if the engine had been off for a few minutes.
It was a very tricky job to get the plug undone and fish it out with pliers. One of the little plastic tabs on the end of mine was missing but i couldn't see any debris in it. That said 10,000 miles before that i ran engine flush through for 40 minutes because of a timing chain rattle which the flush cured. So evidently the tensioner or VVT cam was losing oil pressure. The flush fixed it. Sent from my SM-G965F using Tapatalk
![]() - Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles UK to Nordkapp in a Yaris
#2 | |
#3 | |
Engine flush timing chain
It could also be something as simple as a different brand of oil at the oil change performed after the flush. This is well known to quiet down an engine and vise versa. If there was a true blocked oil passage to the vvt solenoid then a corresponding code would likely be thrown. I wouldn't necessarily be going crazy with flushes due to one experience
#5 | |
In my case though i have used the same oil for years - Castrol Magnatec 5W30 A5 fully synthetic. After 160,000 miles/12 years i guess some crud built up somewhere. Oh and the flush i used was a "Forte" brand and didn't cure my oil burning issues but i never expected it to. Sent from my SM-G965F using Tapatalk
#6 | |
![]() ![]() Drives: Yaris 2008 Sedan Join Date: Nov 2010
The reason I'm suspecting the VVT is part of my ongoing quest to find out the cause of my engine vibration. After lots of research, it seems this could be a possibility, and it's not so cheap to replace. I used techstream to play around the other day, turning on the OCV solenoid during idle D/R actually made the rpms rise and the engine vibration settled out as if it was in N. Not sure if this is evidence, but it's drive behind my reasoning. |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| ***The Engine Oil Bible*** | Hussain-Vtec | Performance Modifications | 20 | 09-28-2016 02:47 PM |
| Question replacing head gasket. | Snyprwlf47 | DIY / Maintenance / Service | 3 | 07-13-2014 11:17 PM |
