As i stated above, this will be fine but you will dilute your new coolant below 50/50 due to the water left in it. Make sure you test your coolant's freezing point once you swap it out
#2 | |
![]() ![]() ![]() Drives: Yaris manufactured after 2007 Join Date: Nov 2010
I just bought two gallons at the local Toyota dealer, total cost with tax $50 USD. But my worries about corrosion inhibitors and lubricants may be moot, because according to the information on the coolant bottles, the 50/50 freezing point is only -34 degrees Fahrenheit. That is OK where I live now in the Pacific NW of the US, but if I go back to Montana, it is not OK. Because it can get to 40 below in Montana. I will have to call a Toyota dealership back in Montana and ask them what they sell for coolant. Thanks, R. |
#3 | |
I think the actual number is Toyota 00272-1LLAC-01, see this amazon link. I am not sure if this other part number coolant can be delivered to a local Toyota dealer here or not. But I will call tomorrow and find out. Thanks, R. |
| Tags |
| change, coolant, engine |
| AT fluid change earlier than 100k miles | hw6515 | DIY / Maintenance / Service | 25 | 06-06-2014 01:54 PM |
| HELP! Coolant is rusty brown only 30K! | TheSilkySmooth | DIY / Maintenance / Service | 25 | 05-27-2010 08:26 AM |
