Old 06-25-2019, 08:31 PM   #32
RMcG
Drives: Yaris manufactured after 2007
Originally Posted by tmontague View Post
As i stated above, this will be fine but you will dilute your new coolant below 50/50 due to the water left in it. Make sure you test your coolant's freezing point once you swap it out
Thanks tmontague. I did indeed read your previous post about how you run different dilutions and I am aware that the freezing and boiling points change with dilution. I was more worried, however, about the effect of dilution on the corrosion inhibitors and the lubricants.
I just bought two gallons at the local Toyota dealer, total cost with tax $50 USD. But my worries about corrosion inhibitors and lubricants may be moot, because according to the information on the coolant bottles, the 50/50 freezing point is only -34 degrees Fahrenheit. That is OK where I live now in the Pacific NW of the US, but if I go back to Montana, it is not OK. Because it can get to 40 below in Montana. I will have to call a Toyota dealership back in Montana and ask them what they sell for coolant.
Thanks,
R.
RMcG is offline   Reply With Quote
change, coolant, engine
AT fluid change earlier than 100k miles hw6515 DIY / Maintenance / Service 25 06-06-2014 01:54 PM
HELP! Coolant is rusty brown only 30K! TheSilkySmooth DIY / Maintenance / Service 25 05-27-2010 08:26 AM
