Old 06-25-2019, 11:50 PM   #1
seatech30
Drives: Yaris 2008 Sedan
Originally Posted by zoidberg444 View Post
I cleaned mine when i did my last oil change. I doubt there would be any oil in it if the engine had been off for a few minutes.
It was a very tricky job to get the plug undone and fish it out with pliers. One of the little plastic tabs on the end of mine was missing but i couldn't see any debris in it. That said 10,000 miles before that i ran engine flush through for 40 minutes because of a timing chain rattle which the flush cured.
So evidently the tensioner or VVT cam was losing oil pressure. The flush fixed it.
Sent from my SM-G965F using Tapatalk
Sorry, I might be mixing it up, how did you clean the VVT? By removing it then flushing it somehow? I was thinking I could probably pull it out, and soak it in brake cleaner or maybe give it 12V and give it a good spray.
The reason I'm suspecting the VVT is part of my ongoing quest to find out the cause of my engine vibration. After lots of research, it seems this could be a possibility, and it's not so cheap to replace. I used techstream to play around the other day, turning on the OCV solenoid during idle D/R actually made the rpms rise and the engine vibration settled out as if it was in N. Not sure if this is evidence, but it's drive behind my reasoning.
seatech30 is offline   Reply With Quote
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
