#1 | |
I have the Scion xD engine control diagrams if you don't. I'd be happy to send that to you if you wanted to let me know if my switched power is actually switched. ![]() Thanks again!
#2 | |
2ZR swap. DO IT! Ask how!
I should have a copy at home but might not have time to review it tonight. |
#3 | |
I did get a hint from the AEM guys. They feel that one of the wires on the TPS is a signal ground. They also said that I do not need to hook up the two 02 sensors and suggested that the most simple setups seem to be the least problematic and most stable. I also sent my questions, along with diagrams to the turbokits.com guys and Jesse, the lead tech, is sending them to the guys that make the Plug and Play harnesses. So, hopefully I will have definitive answers soon. If you do get a chance to review your diagrams, I'd be thankful, but only if it's not, in any way, an inconvenience for you. I really appreciate the thoughtful and informative responses that you've given so far.
| 3rd gen 2zr swap with 6 speed | stidnam | Performance Modifications | 97 | 06-29-2021 04:59 AM |
| Hyundai Turbo Veloster 150kw | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 6 | 01-09-2012 11:35 PM |
| ZPI Turbo for one lucky Yaris owner..... | ZPIracing | Forced Induction Forum | 27 | 04-26-2007 10:36 PM |
