![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
hatchback drivers-passenger door plate removal?
Not sure what this thing is even called but its part of the B pillar?
I would like to remove for paint without damaging if possible. https://i.imgur.com/Sh8b9At.jpg |
#2 | |
I polished mine with my DA polisher and a polishing compound and applied a few coats of Klasse SG acrylic sealant. They came out great.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 07-02-2019 at 08:14 AM. |
#3 | |
I just had my car painted(3 base+ 3 clears)and know the plastic looks really weathered.I did paint the parts around the side mirrors that came off easily.Know to finish it off completly I will paint the door plate thingy. I could mask but prefer to have the part off so I can prep it more easily and not have to mask. Every part that I could remove including badges were removed for spray. |
Officially, I believe it's called an 'applique'. Someone else asked about them recently and since I had mine replaced early in my car's life due to some spotting, I was familiar with them. They pop off and can be replaced or as 06 indicated, can be restored. More info including part numbers here:
http://www.yarisworld.com/forums/showthread.php?t=61884 |
#5 | |
The universe doesn't feel right to me thinking I corrected you on something automotive
![]() You were and are right, though, they can be restored. |
#7 | |
| Had an accident now passenger seatbelt and driver's airbag light won't go off | Scoey | DIY / Maintenance / Service | 9 | 12-15-2022 03:29 AM |
| 2007 Yaris Hatchback Lock Cylinder Removal | Cigar_Maverick | DIY / Maintenance / Service | 0 | 10-27-2016 10:17 AM |
| Front passenger seat removal & SRS, seat belt issues | RMcG | DIY / Maintenance / Service | 12 | 11-06-2010 12:43 AM |
