Old 07-02-2019, 05:35 PM   #4
roachslayer
Drives: 2013 SE
No cracks. Just looks like a bad design. These light assemblies simply sit on the body with a foam gasket. Mine is not damaged, but apparently it leaks, so it obviously doesn’t work very well.
I don’t want to seal it with RTV or anything, so I simply added a little silicone tape between the body and the gasket in hopes that a little more material there might seal it. Could have made it worse. I dunno. But this is very annoying.
Easy to pop out, btw, in case anyone ever has to do this. Two 10mm nuts are obvious in there, but you then have to carefully pull it out from all the holding pins, AND it’s best to pop the bumper out of the way first too (no need to remove it, but at least carefully pull the bumper back from its clips)
roachslayer is offline   Reply With Quote
3rd Gen Vitz RS (and G's) Tail Lights: Part Numbers, Ordering, and Installation keiri Third Gen Yaris General Discussion 26 09-04-2020 12:01 AM
Yaris 2007 tail lights change to TS VERSION HELP Roberto Borges General Yaris / Vitz Discussion 2 04-07-2019 02:54 PM
Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal V70R_Blackbrick Cosmetic Modifications (Exterior/Interior) 26 11-27-2013 10:14 PM
LED tail lights installed Cutie Pie #2 Cosmetic Modifications (Exterior/Interior) 10 08-20-2012 11:25 PM
Tail lights for 09 sedan piepie Cosmetic Modifications (Exterior/Interior) 7 06-03-2009 09:24 AM
