![]() Drives: 2010 Toyota Yaris 5dr Join Date: Jan 2011
Super simple to install cruise control on a 2017 Yaris.
Got my control stalk from Amazon.com $19. Have seen even cheaper, after I got mine coming. Released the three springs holding the airbag on, didn’t disconnect anything. Laid it on top of steering wheel. Screwed the stalk on with the included screws. Popped the airbag back on. Turned on the key and pushed the on/off button. IT WORKS. ! Took Dremel tool to side cover that goes around the stalk. Total time 4 minutes... Yes you read that right. To get cruise control on and works flawlessly ! And I didn’t spend $229 for a Rostra cruise kit (stalk and a few wires that you won’t need) |
![]() ![]() Drives: 2015 Yaris L Join Date: Jun 2017
Not to nitpick, but I hope you unhooked your battery terminals and cleared residual electricity by waiting 10 min. or so and depressing the brake pedal. Stray electricity and air bags aren't something to mess with.
In any case congrats on your new cruise control. When I installed mine it really redefined my driving experiences on the interstate. No more sore ankle. |
No. I usually don't unhook a airbag depending on what I am doing. If I were to unplug the airbag. then yes. But since I was just sitting it out of the way, no.
#4 | |
![]() ![]() ![]() Drives: 2017 Yaris L (5sp manual) Join Date: Jun 2012
Also, do you have a link to the stalk you bought at Amazon? Thanks again! |
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
See the thread 2 below this titled "DIY Cruise Control for 2012 Yaris - Good News!".
There are diagrams and pictures of how to undo the clips to remove the airbag. This is also the horn button, so either disconnect the battery or remove the horn fuse before you try to reinstall the airbag. It just pushes back on, but will sound the horn while you are pushing on it. If you have a manual transmission, there is also a switch that you will need to add to the clutch pedal. This cancels the cruise control any time you push the clutch pedal, so the engine doesn't rev sky high when changing gear.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
![]() Drives: Hatchback Join Date: Jun 2019
2017 Yaris L Cruise control
I got everything here for my daughters 2017 Yaris L , stalk and cover. Toyota Yaris Vios Cruise Control Switch 84632-34011,84632-34017
Sent from my iPhone using Tapatalk Last edited by Zippy_2019; 07-17-2019 at 05:41 PM. |
For Toyota Yaris Vios Cruise Control Switch 84632-34011,84632-34017 https://s.click.aliexpress.com/e/6hh9Jgy Sent from my iPhone using Tapatalk |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| cruise control yaris 2009 install | Prakersa | DIY / Maintenance / Service | 6 | 05-15-2018 06:26 AM |
| Yaris Cruise Control Auto | evarkey | Performance Modifications | 1 | 07-02-2014 07:56 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
